92 toy PU 4wd v6 extra cab auto/ 88 5 speed 4 banger
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Drivetrain
supratruck88Offline
Avatar
PostPosted: Tue Sep 18, 2007 10:53 am    Post subject: 92 toy PU 4wd v6 extra cab auto/ 88 5 speed 4 banger Reply with quote
I got a rolling chassy for $25 from a friend. So I was wundering what is upgradable from a 92 v6 to an 88 4 banger.
1.) Are the tortion bars and sway bars stronger? The tortion bars looked the same diameter
2.) are the rotors and calipers stronger?
3.) Noticed some kind of extra system connected to the brakes and power steering, whats that? Its on the passenger side and has 2 brake lines and 2 power steering lines
4.)And I will be taking the entire rear axle and swapping the lsd and my traction bar on to it. Not sure of the spring setup though. With my flat bed, I think I'm around 200 lbs extra. My buddy had some old ford leafs and I through one of those in and a year later there all on the load spring again. The newer ones have some life left in them. Should I combine some of the old with the new? and the v6 upper leafs are longer then mine, not a direct bolt up.
Thanks Kevin
88 toy 4wd, 7mgte, 32''s, custom bed
My Site http://www.cardomain.com/ride/647331
View user's profile Send e-mail Visit poster's website
supratruck88Offline
Avatar
PostPosted: Thu Sep 20, 2007 10:46 am    Post subject: Reply with quote
The tortion bars might be the same. It looks like the 92 had the nuts screwed down alot farther.
Not sure about the other things i listed.
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Drivetrain All times are GMT - 6 Hours
