Fuel Pump?
YellowJacketOffline
PostPosted: Sun Oct 24, 2004 1:41 pm    Post subject: Fuel Pump? Reply with quote
So I was on the freeway and even when I accelerate slowly, I can't even do 90MPH up a hill because it feels like it's cutting out. When I would drop gears it can't handle it either. The weirdest part about it is it use to do better. Even though I have a 7M fuel pump, I have yet to install it, so I am running on the 4 cyl fuel pump. I don't have my intercooler hooked up yet either. I have been told that it's the fuel pump. Is that all it is?
87 4Runner - 7M-GTE, SAS, Locked, 8" lift, 35" BFG's, 4.88 gears
82 Toyota Truck - 22RE, 6" lift, 32" BFG's, 5.29 Yukons, locked front & rear, "super-cabbed" SOLD
Blue Ribbon Coalition
PostPosted: Wed Oct 27, 2004 9:42 am    Post subject: Reply with quote
check for 3 things.
TOBIN...CHANGE YOUR FUEL PUMP. You can access your fuel pump under your seat I thing. The 85 4runner I did was that way.
Check your fuel filter.
Check for boost leaks.
YellowJacketOffline
PostPosted: Sat Aug 20, 2005 10:05 am    Post subject: Reply with quote
"ONE YEAR LATER"
I installed my 7M pump and also went over to my best bud's house and fixed the boost leaks and it still freaks out at 80 MPH?!?!!?
There's got to be something else other than the filter, or is that most likely my next step?
tu12boOffline
PostPosted: Sat Aug 20, 2005 4:15 pm    Post subject: Reply with quote
next step is www.autotrader.com and sell it Razz
I have no idea what that could be, but another good place to check would be socalsupras.com. seems these boards are pretty much dead so your chances are better on supra forums to get some help.
good luck and lets us know what it was if you fix it.
-Isaac
PostPosted: Sun Aug 21, 2005 9:07 am    Post subject: Reply with quote
It is probably that knock sensor of yours. Get it fixed, clear all your codes, then we will see if we have that problem at 80.
Come down and pull the motor out of my supra, and I will work on your 4runner.
YellowJacketOffline
PostPosted: Fri Oct 21, 2005 10:54 am    Post subject: Reply with quote
-Isaac
WOW, you sound like my "anti-supra swap" buddies!
YellowJacketOffline
PostPosted: Fri Oct 21, 2005 10:57 am    Post subject: Reply with quote
Dang, I should have checked that out before I started the SAS!
