r 150 vs 151
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Drivetrain
deaths_demiseOffline
PostPosted: Wed Jul 11, 2007 11:19 pm    Post subject: r 150 vs 151 Reply with quote
ok there is a few things i know about the two tranis, 151s gear t-case vs a chain t-case in 150. and i believe there is more spline on the output shaft of the 151 than the 150. i wanna gear way down in the diffs but still be able to run 80-85 on the highway without tapping out when i to a 7m na conversion. also i wont be doin much crawling, but will be deep sno driving in the winter. mainly it will be a desert truck so what would yall who are good with tranis recommend? thanx
PostPosted: Wed Jul 25, 2007 12:25 pm    Post subject: Reply with quote
The R150 and R151 both have large output shafts. The difference between th e two is the tail housing.
The R151 is for use with a gear driven t-case, and the R150 is for a chain driven t-case.
There are no options for gearing down on the chain driven as there are with the gear driven. Problem is, the R151's are hot and people want a premium for them. Plan on $700 for an R151.
PostPosted: Wed Jul 25, 2007 2:02 pm    Post subject: Reply with quote
ok to get this right if the t-case is not an issue due to no heavy crawling needed, the 150f is a better and cheeper bet. gearing of the trani itself and the torque tollerances of the shafts are my biggest worry... thanx so much
PostPosted: Wed Jul 25, 2007 2:06 pm    Post subject: Reply with quote
The R150 and R151 are equal in strength. Most people would prefer the R151 due to the gear driven t-case which is stronger than the chain driven, and that you can get a gear reduction of 5.0 from the stock 2.3.
R151 also has a VERY low first gear, which depending on your application, could be a good or bad thing.
PostPosted: Wed Jul 25, 2007 10:17 pm    Post subject: Reply with quote
sweet thank you and are you still doing custom bellhousings for a few hundred?
PostPosted: Thu Jul 26, 2007 9:20 am    Post subject: Reply with quote
Probably going to be around $400. Machine work ended up being a little more.
PostPosted: Thu Jul 26, 2007 2:16 pm    Post subject: Reply with quote
awesome thats what i figured, thanks so much man... this site is freaking awesome and helpful... how is your back mate... didnt you injure it a while back?
PostPosted: Thu Jul 26, 2007 2:35 pm    Post subject: Reply with quote
Glad I can help.
Yeah, back is still messed up. My doctor is parting with someone starting next month that does endoscopy. I am going to give that a try, hopefully there is at least some improvement. I don't care if it is just a little, some is better than none.
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Drivetrain All times are GMT - 6 Hours
