Which 3 core Rad.... 22RTE or 3vze
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Cooling - Radiator and Intercooler ideas
PostPosted: Tue Jun 07, 2005 9:47 am    Post subject: Which 3 core Rad.... 22RTE or 3vze Reply with quote
I'm wanting to keep the factory hood latch so I was thinking about using a factory toyota 3 core radiator with a taurus fan mounted in front of it in my 85 4Runner. I asked my local NAPA the specs on the '87 22RTE or '88 3vze since they are both 3 core radiators. They said the 22RTE was 1 1/4" thick where the 3vze was 2" thick but they are both 3 core....
Here is the radiator that I curent have in my '85 4runner.
______________________________________________________
Modine Radiator
Napa #MO945
Price: $ 152.00
Attributes: Radiator
Make: Toyota
Core Size: 15 3/4'' x 20 3/4'' x 1 1/4'' (2 Row)
Inlet Header Size: 1 1/2'' x 20 3/4''
Outlet Header Size: 1 1/2'' x 20 3/4''
Inlet Connector Size: 1 3/8'' Right
Outlet Connector Size: 1 3/8'' Left
Type of Mount: Double Flange
Oil Cooler: 14 3/8'' w/ Adaptors
Comments: Smaller fillerneck cap
Engine=2.4 L 2366 CC L4 22R SOHC
Engine=2.4 L 2366 CC L4 22REC
These are the ones that I'm thinking about getting
that should bolt into my '85 4Runner.
Power Flow Radiators Radiator
Napa #PFR192272
Price: $ 176.00
Make: Toyota
Core Size: 19 1/8'' x 20 3/4'' x 2'' - 3 Row
Inlet Header Size: 2 1/8'' x 20 1/2''
Outlet Header Size: 2 1/8'' x 20 1/2''
Type of Mount: Front Flange Mount
Oil Cooler: 5/8/14
Engine=3.0 L 2958 CC V6 3VZE SOHC
Napa #PFR190945
Price: $ 121.00
Make: Toyota
Core Size: 15 3/4'' x 20 3/4'' x 1 1/4'' - 3 Row
Inlet Header Size: 1 9/16'' x 20 3/4''
Outlet Header Size: 1 9/16'' x 20 3/4''
Oil Cooler: 10 7/8''
Engine=2.4 L 2366 CC L4 22RTEC
Engine=2.4 L 2446 CC L4 2LT Diesel
Have you guys used the V6 radiator in a 84-88/89 truck with success? or is it too thick to reuse the stock mounting location?
PostPosted: Tue Jun 07, 2005 3:19 pm    Post subject: Reply with quote
i couldnt use a radiator in the stock location, i had to cut the front body work and mount it slightly under the hood latch, since i have a 2inch body lift i was able to retain my hood latch function at the same time. I'm currently using a stock mk3 supra radiator, plan on keeping it unless i have some cooling problems with it. I also use flex-a-lite low profile fans and have plenty of clearance between the fans and water pump pulley.
94 4runner
7MGTE / SAS / 35in MTRs
PostPosted: Wed Jun 08, 2005 8:55 am    Post subject: Reply with quote
From what I've seen and foudn by searching so far is that the 89/90 -95 body style seems to have a slightly smaller engine compartment. Is that true? And if it is, can anyone shed some light on the 84-88/89 body style and their radiator?
PostPosted: Thu Jun 09, 2005 1:52 am    Post subject: Reply with quote
I haven't looked into it, but I was thinking it would be great to run a dual pass radiator, with both necks on the passenger side. You can apparently just rotate the thermostat housing 180 degrees and remount it like that, and then just run a bend to the radiator neck. I think the dual pass units are a little more pricey, but it would clean things up a bit inside. Also, if you are making your own frame side mounts you can set it up to where you can fit an electric fan and the radiator behind the hood latch cross member.
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Cooling - Radiator and Intercooler ideas All times are GMT - 6 Hours
