Watch think 'bout this
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Drivetrain
UNBREAKABLEOffline
PostPosted: Tue Jun 07, 2005 9:00 pm    Post subject: Watch think 'bout this Reply with quote
I think that instead of running dual t-cases I'm gonna run dual W-56 trannys and a single case(maybe 4.0's in it) I'm gonna rebuild them with Marlin's HD rebuild kit http://www.marlincrawler.com/w56-d_trans.html My 2nd tranny shifter would come out near the seatbelt buckle, I can make linkage to shift the tranny from the location of the factory t-case hole and then twin stick my t-case with linkage.
First gear is 3.95:1 X 3.95 X 4.0 X 4.56(I have D60 front and a D70w/ detroit in the rear Very Happy I would be over 280:1 crawling!
PostPosted: Tue Jun 07, 2005 10:28 pm    Post subject: Reply with quote
Good luck!!!!
I really don't think Dual trannys is a good idea behind a 4 cylinder, let alone a 7M......
:BOOM:
PostPosted: Tue Jun 07, 2005 10:57 pm    Post subject: Reply with quote
thats what i was gonna say, multiplying torque from the 7M into a 2nd tranny doesnt sound like it would last long
94 4runner
7MGTE / SAS / 35in MTRs
UNBREAKABLEOffline
PostPosted: Wed Jun 08, 2005 5:58 am    Post subject: Reply with quote
I've already thought about that. But as long as I be easy It might be survive. If it doesn't, I'll send the guts to Bobby Long and have them cryo'd.
PostPosted: Wed Jun 08, 2005 8:07 am    Post subject: Reply with quote
Whats the point of having a 200+HP 7M if you have to "go easy on it"..... Might as well just stayes with the previous motor IMO.
Seriously, I'm concerned about running (1) W56 and keeping it alive with my dual ultimate cases, detroits front and rear with 5.29 gears, 36" IROKS. BTW I'm not that worried about axles since I'm already running Cyro gears, 27 spline PIGs w/ Chromo Longs, 5 stud knuckles, ARP hub studs, and 6 pin install on the the hubs.
Also the dual trannies is not even trail tested yet over the long haul.
PostPosted: Wed Jun 08, 2005 8:08 am    Post subject: Re: Watch think 'bout this Reply with quote
BTW dual reverse will be even lower than dual 1st.....
UNBREAKABLEOffline
PostPosted: Wed Jun 08, 2005 10:53 am    Post subject: Reply with quote
I know where there is one that has been in for a while Very Happy
What about an auto in front then into a manual? Converter would allow for some slippage. My only ? would be how to shift the manual into gear. On the road it wouldn't have to be change. I guess off road I could just put the auto into neutral and put the manual into gear then shift the auto back into 1,2,3 or D
PostPosted: Wed Jun 08, 2005 11:23 am    Post subject: Reply with quote
crazy people, just do dual cases Rolling Eyes
its easy and known to work and hold up to abuse
94 4runner
UNBREAKABLEOffline
PostPosted: Thu Jun 09, 2005 4:37 pm    Post subject: Reply with quote
I've already done that. Time for something different.
Strive for perfection in everything.
Take the best that exists and make it better.
If it doesn't exist, create it.
Accept nothing nearly right or good enough
Sir Henry Royce
eRICKOffline
PostPosted: Thu Sep 04, 2008 11:27 am    Post subject: Reply with quote
If you take it easy on that straight 6, you will be applying less force to the dual tcase because the stronger engine produces more raw low end power
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Drivetrain All times are GMT - 6 Hours
