cutting fenders
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Anything Goes
claytonfaulknerOffline
PostPosted: Wed Oct 19, 2005 9:26 pm    Post subject: cutting fenders Reply with quote
this may be stupid but how exactly do i cut out my fenders? also what size tires will i be able to fit without a lift and cut out fenders?
4RnrRickOffline
Avatar
PostPosted: Thu Oct 20, 2005 9:46 am    Post subject: Reply with quote
Sawzall, Jigsaw, Cutoff Wheel
Just depends on how much lift, what tires size, axle location, and most importantly what vehicle your taking about.
I've trimmed mine "a little" on my 85 4runner....
~4" of lift, 2" body lift, 36" Iroks, 108" wheel base (stock is 103)
Project Quasimodo
'85 Xtra Cab (2wd, 22RTE, Auto => 4wd, 3RZ, w56, 2.28x4.70)
PostPosted: Thu Oct 20, 2005 2:55 pm    Post subject: Reply with quote
its a 95 pickup with not lift and ifs, i really want to squeeze 33's under it
4RnrRickOffline
Avatar
PostPosted: Thu Oct 20, 2005 3:39 pm    Post subject: Reply with quote
From my understanding with NARROW 33"s and stock rims with no lift, they will just barely rub. PM Toyofast on Pirate4x4.com for more info because I think he was doing it on his daily driver. He might of cranked the torsion bars....
Project Quasimodo
PostPosted: Thu Oct 20, 2005 4:06 pm    Post subject: Reply with quote
how do u crank the torson bars? my rims arnt stock but im not sure what the back space is>?
YellowJacketOffline
PostPosted: Thu Oct 20, 2005 11:26 pm    Post subject: Reply with quote
You want a 22mm socket on a 1/2" impact gun. Don't waste time with doing it any other way. Use lots of WD40. You will need to hold the top part with a wrench. Can't remember what size that was. Maybe also 22mm. Just follow the two bars along the frame. I just got done cutting mine all out!
87 4Runner - 7M-GTE, SAS, Locked, 8" lift, 35" BFG's, 4.88 gears
82 Toyota Truck - 22RE, 6" lift, 32" BFG's, 5.29 Yukons, locked front & rear, "super-cabbed" SOLD
Blue Ribbon Coalition
View user's profile Send e-mail
4RnrRickOffline
Avatar
PostPosted: Fri Oct 21, 2005 9:13 am    Post subject: Reply with quote
BTW you forgot to tell him to jack up the vehicle and block it so the front suspension is off the ground before you start, otherwise you will stip out the threads...... Been there done that!!!!
Project Quasimodo
S-M-R-TOffline
PostPosted: Fri Dec 15, 2006 9:06 pm    Post subject: Reply with quote
I did not want to do my T-bars so I did a 2" body lift instead. Clears 33s easily. I also trimmed my fenders first because I was impatient and wanted to get my new 33s on before I had any lift. Well I can tell you that fender trimming alone is not enough but a jigsaw with a little tape over the bottom so that it doesn't scratch your paint makes a nice clean cut. Much better then a zawsall.
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Anything Goes All times are GMT - 6 Hours
