R154 Clutch Set-Up
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Drivetrain
supratruck88Offline
PostPosted: Sun May 07, 2006 7:59 pm    Post subject: R154 Clutch Set-Up Reply with quote
Well the W56 finally lost a tooth in second gear in 5000 miles, so I'm going with the R154 and will later put in a divorced t-case. I have a RPS 6 puck clutch on the w56 right now and was wundering if I can use this set up in the R154 with the R154 throw-out bearing, clutch fork and slave cylinder? I still have the old clutch set up but I would need to get the flywheel turned. The clutch doesn't look that bad but not sure if it is a stock set-up. Oh and every mile of the 5000 was well worth it. Very Happy Thanks
88 toy 4wd, 7mgte, 32''s, custom bed
My Site http://www.cardomain.com/ride/647331
supratruck88Offline
PostPosted: Tue May 09, 2006 8:22 pm    Post subject: Reply with quote
Found out the RPS clutch setup won't work. I'm going to just use the stock set-up from the R154.
PostPosted: Sun May 21, 2006 9:43 am    Post subject: Reply with quote
That sucks. OH well, gotta do what you gotta do.
7m4runnerOffline
PostPosted: Thu Jun 08, 2006 4:53 pm    Post subject: Reply with quote
How much power were you runnin, I was planning on running the 7mgte with my w56 for a time till i got time to do the r154 tranny swap.
supratruck88Offline
PostPosted: Wed Jun 14, 2006 10:35 am    Post subject: Reply with quote
the stock motor was 232 hp, freed up the intake and exhaust, with a little more boost, i think i'm around 270 hp but not sure. I would baby it into gear and then hammer it. With the R154 this thing really flys now, I'm lovin it. Sellin the clutch and pressure plate on e-bay now, still have other parts of the w56 set-up if u need them.
hiluxuryOffline
PostPosted: Sat Aug 26, 2006 5:08 am    Post subject: Reply with quote
i was just wondering wat model hilux do you have??? because im doing a 7mgte swap and i was luck to get a r154 gear box with it too.... and i would just like to know that did you have to shorten/extend your tail shaft? wat t-case are you using.... is it runnig 4wd now or just 2.
sorry for the questions bit scared on the conversion, motor should be here any day now....
thankx
supratruck88Offline
PostPosted: Tue Aug 29, 2006 10:36 am    Post subject: Reply with quote
I have an 88 4wd pu. I took the 2 drive shafts of the parts car before i got rid of it , so i used the short 1 that was connected to the tranny and has a carrier bearing connected to it . This fell short of a cross member by a couple inches so i made a bracket to hold that. then for the 2nd half i shotened my stock driveshaft by about 11 inches useing the same end on it. It bolts right up. So I'm 2wd right now but i plan on getting an adapter from www.advancedadapters.com to work with the stock w56 tranny transfer case and make it back into a 4wd. You will like the r154 tranny if you like goin fast.
hiluxuryOffline
PostPosted: Wed Aug 30, 2006 5:42 am    Post subject: Reply with quote
thanx for all the info thats heaps of help ill try to keep you up to date with my progress here down under.... i love to go fast to i knew that the r154 would be able too handle it.... i went for this conversion because the 3Y was gutless....
thankx heaps...
hiluxuryOffline
PostPosted: Wed Aug 30, 2006 6:08 am    Post subject: Reply with quote
do you mind sending me some picks of your truck to my e-mail at el_spanko_diablo@hotmail.com thankx heaps supratruck88
supratruck88Offline
PostPosted: Wed Aug 30, 2006 10:44 am    Post subject: Reply with quote
hey, i put my cardomain site in my signature. I'll try and post some new pics of my drive train set-up soon. I ended up using the stock tranny support and built a bracket that was like 4-5 inches forward and higher. Not sure how things will line up once i go to put the t-case in. Hopefully there will be enough room for the front drive shaft to pass through without hitting.
hiluxuryOffline
PostPosted: Thu Aug 31, 2006 4:54 am    Post subject: Reply with quote
thats a cool ride hey..... thankx for the pics..... i can't wait to start my conversion still waiting for the motor to pass customs should be getting the phone call any day now...
thankx again ill keep you posted on my conversion
hiluxuryOffline
PostPosted: Fri Sep 01, 2006 7:58 pm    Post subject: Reply with quote
i also wanted to ask hat diff are you running still standed or from another car.... or upgrades to the original
supratruck88Offline
PostPosted: Thu Sep 07, 2006 10:59 am    Post subject: Reply with quote
i have the stock 4:10 gears and diff.(didn't break yet), but i have the LSD diff from the car and plan on swapping it into the truck with the third member from a v6 p/u. Then i believe you just have to use a spacer from the car and truck to make it fit.
hiluxuryOffline
PostPosted: Mon Sep 11, 2006 7:46 am    Post subject: Reply with quote
i was just woundering but i think i may go for a air locker system for front and rear of the car not very expensive over here and they say that it is more then double the strength. the one i'am getting has no pins in the air lock diff just one piece. but thankx for the info wasn't really sure if the stokie could handle it.
my motor was held back in japan for another month so still have to wait a while and the cops over here aren't making it easy to do the convertion either.... i hope they will lwt me do it.
PostPosted: Sun Sep 17, 2006 12:07 am    Post subject: Reply with quote
I wouldn't put in an air locker right away. If you blow up the rear end you will most likely ruin the ARB aswell.
Post new topic   Reply to topic    www.supracharged.com Forum Index -> Drivetrain All times are GMT - 6 Hours
